HFS-4 Q&A, application for your engine...
Re: HFS-4 intro...
"What is in the box" ? 6M of 6mm OD nylon hose (806-261). 2M of 4mm OD nylon hose (806-266) ? HFS-4 Electronic controller ? 0.8 mm water jet (806-323) in plastic bag ? 0.9 mm water jet (806-324) in plastic bag ? 1.0 mm water jet (806-325) in plastic bag ? 1x 4mm Tee compression fitting (806-395) in plastic bag (new for 2.12 kit) ? 2x M8 x 1/8 NPT jet adapter with plug (806-357N) ? A set of three restrictors with insertion tool ? 1x water tank adapter 1/8 BSP (806-270), 6mm compression fitting and in-tank filter (806-258) ? 4x M5x40mm bolt, washers and fasteners for pump ? 1x M6 grounding stud with washer and nuts and 6mm eyelet for pump ground. ? 2x 6mm to 1/8 BSP compression fitting for pump.. ? 2x 3/8BSP-M to 1/8BSP-F reducer for pump. ? 1x 4mm to 1/8 BSP compression fitting for FAV. ? 1x 6mm to 1/8 BSP compression fitting for FAV. ? Water pump harness. 6M of #12 AWG cable and 6M of multi-core cable with blue harness. ? 1x Fast acting valve with red harness ? 1x turbine flow sensor with yellow harness ? 1x water level switch with connector (806-281c) ? 1x DDS3v12 Gauge with 1.5M x 8-way cable ? 2.0 M of multi-core with grey capped RJ48 for ECU interface, fail-safe and map switching. ? Molex type 4-way power in harness ? Green harness for Direct injection engines (v2.12). ? User manual Generic wiring diagram: http://www.aquamist.co.uk/HFS4/H4-generic-wiring.gif components in the kit: Gauge: http://www.aquamist.co.uk/forum/dds3gauge.jpg Compression fittings (zero leak) http://www.aquamist.co.uk/forum/c-fittings.jpg More to come... More to come... |
Re: HFS-4 intro...
subscribing for group buy.
Re: HFS-4 intro...
GB details will be up this weekend.
Re: HFS-4 intro...
Re: HFS-4 intro...
We will probably need 20+ people for the GB to materialise. Hopefully it will happen.
Re: HFS-4 intro...
Compatible with DI on Mazdaspeed 6 / 3?
Re: HFS-4 intro...
is this basically for newer cars and would this have no major improvements over the hfs3 on an 92 rx7
Re: HFS-4 intro...
Re: HFS-4 intro...
Think of the H4 as the H6 (discontinued) replacement rather a newer H3. |
