Race pump capable of 2x 0.8 nozzles?
Hello,
As per above: I want to convert my 2d system with the 'race pump' (that was in the kit) to a two-nozzle system by adding a Y-piece and using an extra nozzle as I am using 4x ID1000 injectors at 3.5 bar FP and currently just one 0.9 nozzle which gives me just 7% mixture (50/50) to fuel ratio. Can the race pump handle this resulting 2x 0.8 nozzles = 580cc mixture flow?? If not, what are my options? Thanks in advance, Walter |
Re: Race pump capable of 2x 0.8 nozzles?
The 2d cannot spray more than 330cc/min.
You can use a push pump (washer pump) between the tank and aquamist pump, it will just about to manage 580cc/min. |
Thanks Richard,
That was my fear from looking at the flowchart.. I run batch fire for fuel injection, but maybe you know if DTA (s60-pro) fires per side (so not really a batch of 4 but a batch per 2 cylinders)? That way I might be able to use your method with the two diodes and triggering the 2d twice? If that doesn;t work, do you sell such a pusher pump? I fear the small 4mm lines might not fit any window washer pumps. Fitment of lines is usually a nuisance when you start fabricating on your own.. Walter |
