Am I the first to put it on an LS1 (F-body or Corvette)
I have a question about the injector signal wires. I'm running an LS1 that is in a 2000 Firebird Trans AM (LS1 motor) and I found the signal wire for the injectors, but no the ground. I'm guessing it's a common ground for each injector. I was planning on tapping the signal right at the pcm, but I can't find an injector specific ground.
Here's a list of the pinouts on our pcm's: http://www.lt1swap.com/2001_PCM_CONN_PINOUT.htm As you can see, I plan to use the pinout for the #1 injector, which is positon #36, but there is no #1 ground. Has anyone installed this on an LS1 before? |
Re: Am I the first to put it on an LS1 (F-body or Corvette)
Most PCM switches the injector to ground to open it. Injectors are all connected to common 12V.
Green wire of the grey harness would go to pin 36, you could connect the red wire of the grey harness (12V system ON signal ) to pin 57 if it is switched (pre-crank) power.
There might me a better one for the red wire, but that would probably work. |
so it appears this is along the same lines for me for a L76 (ls3ish) style pontiac g8 gt
