GTR35 Wiring Diagram for HFS-3
Hi Richard,
Wondering can you help on this? I am looking for a wiring diagram to fix on a HFS-3 on a Nissan GTR35. I found one on goggle which show HFs-6 wiring application. I connect Pin 17 which show F.IDC(-),the pump will start to spray. Can you advise is this wiring diagram not right? Regards, Gan(Singapore) |
Re: GTR35 Wiring Diagram for HFS-3
have you checked this forum?
Thank for the info.I got it all wire up and face a new issue. When we on the iginition,the pump start to on. F-IDC,Thres and 95% IDC all light up. What could be the problem? Please help.Thank you Gan |
Make sure you connect the red wire of the grey harness to the correctly. If in doubt, connect it the fuel injector (+)
Which pin is the red wire wired to at the moment at the ECU? |
