Pump above water level - Primer pump needed?
Trying to install my HFS-3 and upon test mounting the pump found that the foglights interfere with the intended mounting location. Thus I need to move the pump higher and sideways for clearance resulting in the the pump head being roughly at the top of the tank.
Can the Aquatec pump that comes with the HFS-3 maintain prime for long periods of time if the pump head is above the water level? If not, is a priming pump recommended with the newer Aquatech pumps? I've seen people talking about it in regards to the older race pumps, and I'm have an unused headlight washer pump on my tank that could be used for this. Aquatec states that: Quote:
This would also require the high pressure inline filter as the tank tap wont be used and the standard disc filter are only rated at 30psi. It also might introduce bubbles into the system when the tank is low as the headlight pump picks up from the front right of the tank, and there wouldn't be any place for air to escape except out the nozzle. The other option is to build a small swirl-pot or surge-tank that will sit above the new pump location. The headlight washer pump would be used as a lift pump in this case, and it would stay at roughly atmospheric pressure. This would require a check valve on the lift pump, surge foam, and a return line with check valve from the top of this tank to the top of the washer tank. The downside of doing this is mostly cost, complexity, and introducing a LOT of leak points. Both options would make the washer pump 100% critical to system reliability and create additional failure points. So is it worth messing with? |
Re: Pump above water level - Primer pump needed?
Are you putting the pump in the engine bay? The aquatec pump can prime from 3 feet up.
If you are concerned about the reliability of the pump, follow the guideline and put the pump in the trunk. Did you read any of the warning in the box? |
Thats an old aquamist based Perrin system. This location is fairly well shielded from heat and elements being outside of the frame rail, under the headlight, and completely covered by the fender liner and bumper cover. Quote:
Car is an estate/wagon and both the underfloor and side pockets in the back are occupied by other equipment. The only area within the cabin left to locate a pump and tank would be under the dash, and that’s probably a worse for a lot of other reasons. I fully understand any and all warranty is voided by installing outside of the recommended location. So any failure of the pump or related electrical harness is an already accepted risk and I’m prepared to replace those components as needed. To improve weather resistance: a vinyl pump cover has been installed, electrical penetrations sealed with liquid electrical tape, airgaps stuffed with dielectric grease, and the junction between the pump cover and pump head has been taped over to further keep water out. The electrical connectors are being swapped out with waterproof AMP connectors, and the relay swapped with a weatherproof one. Heat shielding to the fender well is also being upgraded, so it should stay cool-ish. As the aquatic pump is a diaphragm type so inherently uses check valves to opperate and should in theory HOLD prime without issue. Not only that but the FAV should prevent air form getting in even if these valves had a slight leak. My question was referring to does it hold prime over long periods of time in practice? There seem to be few installs that have the pump slightly higher without issue. But there was also at least one BMW 335i install where the owner was having prime issues. The pump I was worried about reliability was the currently unused Koito centrifugal headlight washer pump in my european market washer tank. I only plan to use this if a primer pump + filter + check valve setup is required. I’m hoping the answer is “no not required”, but am prepared to rig it up if needed. Thanks for the feedback on this (even if it's telling me to RTFM :) ), this kind of willingness from the vendor to discuss the technical ins and outs of a product is one of the reasns I went with an aquamist system! |
I am a bit confused with your set up. Two system is concerned, the aquamist's piston pump and Aquatec pump.
