Old 13-06-2012, 03:47 PM
Oswheel Oswheel is offline
Default failsafe
hey richard i developed a problem in the past few days ... when im in full boost both lights (yellow) are on causing a boost cut the system works fine under normal driving it only does this if i really get on it. im running the new hfs3 with dual 7s jets ..... thanks
Old 13-06-2012, 06:38 PM
Default Re: failsafe
Does the guage show flow?
Old 13-06-2012, 06:46 PM
yes it does, about 7 bars max and B light steady.
Old 13-06-2012, 09:56 PM
Good.
What is the SC. WL and WH set to at the moment? Describe as the face of a clock.
Old 13-06-2012, 11:33 PM
sc at 2 clock, wL 1 clock, wh 10 clock
Old 14-06-2012, 08:15 AM
I think the failsafe setting a bit too aggressive. Please try the folllowing:
SC at 1 o'clcock
WL at 11 o'clock
WH at 1 o'clcock
Old 14-06-2012, 02:07 PM
Thank you sir.I'll try this and report back.
Old 14-06-2012, 03:16 PM
so i set the gauge at the above settings, the only problem im having now is the water level light comes on and stay solid on slight acceleration. before both lights would stay solid on high boost.
Old 14-06-2012, 05:31 PM
There are two things happeniung at th esame time. Failsafe and water level sensor.
Unplug the water level sensor (near the tank) and tell me what the result is.
Old 14-06-2012, 06:59 PM
ok mr Richard here whats happening now . 1. water level sensor unplug.2. failsafe disable from n75 valve.3. gauge still set as you stated above. just came back from test drive, gradually getting into boost no pproblem,then when i step on it full boost both lights comes on solid.flow bars at 7-8 and B light steady at full boost. thank you really appriciate all the help...
