Old 07-10-2007, 11:19 PM
kam_tod kam_tod is offline
Default WI in BMW E30 324 td
Hi guys,
My question is:
Engine M21D24 - BMW E30 324 TD, 115 hp originally, chip-tuned to 140 hp.
Is it appropriate that I use a mechanical injection system from a VW MK2 KR Golf with the air filter box connected to the turbo suction section, OEM injection pump (5 bar), OEM pipes and nozzles to inject W/M mixture?
If yes, what W/M ratio would you recommend. The car is chip-tuned, has not been run a dyno-test but supposedly it should be around 140 hp.
Thanks.
