Old 26-11-2012, 05:11 PM
davidleow89 davidleow89 is offline
Default Jetting size help
Hi Richard, i need a little help here. I am running 4x750cc injectors on my Subaru forester. The Jet size i put in is 1mm with a 0.7 restrictor. Is that correct? As that is the largest jet that came with the kit. But according to the jet calculation guide, i would need a bigger jet. Did i go wrong some where? My target boost is 1.8 bar or 26psi. Please advise. Thanks.
Old 27-11-2012, 03:54 PM
Default Re: Jetting size help
20% of 3500cc/min of fuel =700cc/min of M50W50 should get you started. a 0.8mm + 0.9mm nozzle with a 0.9mm restrictor is about right. A single 1mm is on the low side.
Old 27-11-2012, 05:09 PM
Ok Richard, will get on it asap. Thanks for the help.
