HFS-6 connection to MAP Sensor
I'm just finishing my WI install, and was wondering if the system needs to be connected to the factory MAP sensor, or if there is any alternative way to configure the HFS-6?
The only pressure sensor on my car is the internal one in the Autronic ecu, and I don't fancy soldering a connection to the ecu PCB ! Any help would be much appreciated |
Re: HFS-6 connection to MAP Sensor
The system does not need to be connected to a MAP sensor to function properly, only the IDC signal.
