Old 24-06-2004, 09:44 AM
Race Map Race Map is offline
Default Water Pressure for 1S kit ?
Hello,
Does anyone know what pressure the 1s kit runs between the nozzel (0.4mm) and the pump :?: I wish to fit a pressure gauge to monitor the pressure and am unshore of what gauge i should buy (0-100psi,0-200psi etc)
Once i get use to the correct pressure and if for any reason the pressure climbs higher than normal my assumption would be that the nozzel has blocked.
Thanks in advance.
Jake
Old 24-06-2004, 06:40 PM
Some answer below to your question.
http://waterinjection.info/phpBB2/viewtopic.php?t=234
Old 30-06-2004, 01:18 PM
Thanks Richard L
