Old 06-09-2011, 08:03 PM
killerfox killerfox is offline
Default HFS-3 install MINI Clubman S
I got the kit from Howerton Engineering and have to say it very good quality and that Jeff was always available to answer my questions day or night.
David Fox
Old 29-10-2011, 05:18 PM
Default Re: HFS-3 install MINI Clubman S
Just one very minor observation, can you tiurm the FAV plug upside down by pull the plug corte out and rotate it 180 degrees. You must loosen the cable gland first or you will break the wiring joint inside.
The plug is splash proof as well as the cable gland but not highly IP rated.
