Old 24-10-2010, 12:14 PM
jaxscuby jaxscuby is offline
Talking HFS-6 in 2004 Subaru STi
Installed a HFS-6 kit into friends/client's Sti the other weekend.
We utilized the stock trunk tmic reservoir, but installed float switch & inlet.
Ran the 6mm "hard line" where the factory had routed their lines.
The electrical harness was routed through the rear seat / trunk support
with the 6mm "hard lines". The only thing you see that has to do with
Aquamist in the trunk is the pump.
The engine was given the same treatment.
The only clue is the injectors and their lines.
Tried to cover everything we could with wiring covers.
02 WRX faux STi
ESX TMIC, P/P VF-30 (Deadbolted),
P/P Throttle Body, Colder NGK Plugs
Undrive Pulley, GP-Moto Header, K&N
Helix / Invidia TBE, Tein, STi
Aquamist 2D system
287 whp & 262 ft-lbs @ 16 psi
3XX whp & XXX ft-lbs @ 19 psi
Old 24-10-2010, 12:21 PM
Default Re: HFS-6 in 2004 Subaru STi
also did some road tuning last night.
from most of the cars that i have road tuned, I usually do not
get the sensation of acceleration from passenger seat while
data-logging. but I can say when this turbo gets close to 20 psi
the "suck you back into the seat" starts come on nicely...
so tune finished ~22psi with afr's 11.7~11.5:1, timing was also
added, 3~4 more degrees..
all run through factory ecu with grimm-speed boost control solenoid.
tdo6h-20g, pe 850cc, walboro 255 lph, 1 step colder plus, txs fmic,
plus somethings i'm forgetting.
02 WRX faux STi
Aquamist 2D system
