Old 11-03-2012, 12:40 AM
Default BMW Mini-R56 USDM wiring
Old 11-03-2012, 01:37 AM
brightside brightside is offline
Default Re: BMW Mini-R56 USDM wiring
Thank you! Install starts tomorrow as it will be +12C so the weather is on my side!
Old 11-03-2012, 06:18 PM
Please send some install pictures. Check the underboard settings are matching the above drawing just in case.
Old 22-06-2012, 02:52 AM
Scooter09 Scooter09 is offline
Is this wiring diagram applicable to the 2011+ N18 engine?
Old 23-06-2012, 05:11 PM
I looked into this briefly. The N18 DME is still made by Siemens I cannot verify the the pin out compatibility.
N14 Engine - N14B16AC (171hp / 177 ft-lbs)
* infinitely variable single VANOS (intake only)
* Siemens DME MED17.2 engine management
N18 Engine - N18B16M0 (181hp / 191 ft-lbs)
* infinitely variable double VANOS
* map-controlled oil pump
* variable valve timing (Valvetronic) with 3-phase servomotor and integrated eccentric shaft sensor
* composite camshaft construction
* new piston design
* Siemens DME MEVD17.2.2
Old 17-09-2012, 06:03 AM
ra2fanatic ra2fanatic is offline
Hi Richard,
Excuse me for being the first post I've ever made on this forum, but I've had my HFS-4 installed for about 3 weeks now and I wanted to know if I have this set up correctly...
I have a '10 MINI Cooper S and currently I'm running without any type of restrictor and a 0.7mm jet. The injectors in in a R56-S is rated at 380cc. I'm also running a 50w/50m. Have I set up my system right?
Here's an image of my board...
Old 17-09-2012, 11:24 PM
Welcome to the forum.
I think you should put in the 0.7mm restrictor.
The setting looks good. if you have any slight mis-fire at high RPM, please up your meth ratio.
Can you tell me where are you putting the jet?
Old 26-09-2012, 06:45 PM
Thanks Richard. I have the jet located just after the MAP sensor. I wanted to place it where Jeff Howerton had placed it in his guide on the hard plastic, but knew it was going to take a bit more work to get the hole set up and it was easier access to place the jet.
I was running a 50m/50w, but now trying a 70m/30w mix.
What would cause the mis-fire at higher RPMs?
Old 26-09-2012, 07:51 PM
Did you have a misfire?
Old 26-09-2012, 10:14 PM
I haven't with the current setup.
