wi led on
hi just had my audi tt 1.8t track car fitted with big turbo etc now 450bhp.
the wi led comes on when throttling up. is this normal please. |
Re: wi led on
i checked the nozzle and the line and that appears to be ok. the car was 320bhp, its only done this since the engine upgrade. ive tried adjusting both the wl and wh adjusters and it doesn't seem to make a great deal of difference, the nozzle size is 0.8 is it that it just needs a bigger nozzle. |
Re: wi led on
If you are using a small nozzle, you need to solder link 1&2 so the flow sensor is more sensitive. You nozzle is too small for 450 hp.
Is the 1.8tt is direct injection engine? if it is what is the engine code. You might also need to set the IDC prescaler to x2.5. Which version of HFS3 do you have? Or post the serial number here.
Re: wi led on
I think the engine code is not relevant as it's not standard,it's bored to a 2ltr with forged rods pistons etc, the head has been ported ect.
The block started as bam and cylinder head agu. Injectors are in the inlet manifold (750cc) What size would you suggest for injector as a starting point. Cheers Hugh |
Re: wi led on
The fuel injectors are not DI?
Re: wi led on
I'll get the serial no and get back to you.
What size jet do you think is a good starting point for this bhp Thanks for your help. Cheers hugh |
Re: wi led on
1.5cc/hp for M50:W50 0.8+0.9mm jet
2cc/hp for 100% methanol 0.9+1.0mm jet Based on the standard jets comes with the kit
Re: wi led on
A bit more info whilst I wait for injector info from my engine tuner.
I've fitted a 1.2nozzel checked the lines etc and turned the ids trim up slightly and now the water leval light doesn't come on but the water injection light does come on as injection Starts.the pump is activated during this time. The serial number is 101969. Cheers Hugh. |
Re: wi led on
Finally I have the injector details.
The injector size are 830 and the duty cycle is Max 70% Cheers Hugh |
Re: wi led on
Can you link FDC and tell me how many bars you can see at WOT.
Try the x1.5 IDC scaler if the gauge does not show full bars.
