Old 18-08-2009, 08:44 PM
harcombe harcombe is offline
Default wI on a TD5 Landrover ...still
evening gentle folk.
I am putting a 1S system on my TD5 landrover and am at the final stages of completion, I do however have one question about wiring.
I have a 806-288 race loom which I am condining with a DDS 3 V8 in car gauge. I notice that the DDS interface has a pair of contacts for a level switch whic I have fittedto the washer tank as a fail safe however the loom also has a pair of thin black wires with a connector on it which could in the absence of a DDS3 module be used on a float switch as a pump cut off.
As I have a DDS3 what do I do with these wires as they are part of the race loom???
all posts gratefully received :roll: :lol:
Old 03-09-2009, 08:31 AM
If you have DDS3 gauge, you should have a separate water level sensor. The sensors should be wired and installed independently.
Old 06-09-2009, 10:36 AM
cheers richard
so the DDS water level sensor can over ride the loom float switch sensor...cool.
I guess I can just cut back and terminate.
thanks :lol:
