Old 10-01-2013, 02:27 AM
hotshot25120 hotshot25120 is offline
Default Aquamist HFS4 installation pictures VW Mk6 GTI
Here some picture of my HSF4 installation:
The hardware :
The plan :
ECU Removal :
inside removal :
I pass the wires (view from the engine bay)
View from the cabin behind the glovebox :
fire wall pass :
First ecu connection :
Default Re: Aquamist HFS4 installation pictures VW Mk6 GTI
Product I use to seal the connection after :
behind glovebox final setup :
Solenoid and flow sensor :
trunk route :
Gauge :
Controller :
Old 10-01-2013, 09:40 AM
Thanks for posting such detailed installation, much appreciated.
Any reason for not putting the controller in the grove box? As long as it is accessible, it doesn't matter at all.
It must be freezing in Canada.
Old 10-01-2013, 01:14 PM
The side cover can be pulled really easy and the controller sit perfect there.
and yes its very cold here , -10C to -30C (14F to -22F).
Im still in testing to be sure the failsafe is working but I will be able to test it better this spring because right now its too slippy and the car cut the fuel for the traction control.
Old 10-01-2013, 07:27 PM
Make sure you put plenty of methanol into the way tank.
Old 10-01-2013, 07:28 PM
Very tidy installation indeed. Must have taken you some time.
Old 11-01-2013, 03:08 AM
yeah 2 day to install the kit but I really take my time (vacancy) every connection is secure , every wire is secure.
The only thing im not sure is the failsafe because on the diagram it say "only Mk5" where we need to cut and splice the wire (pin 3 WT/LI)
Old 11-01-2013, 11:59 PM
Some care now will ensure long term reliability. Worth every drop of sweat.
I believe when the diagram is made the MK6 is not on yet on sale.
Old 18-01-2013, 06:33 PM
Any idea how I can test my failsafe ?
I have try to unclip the Water flow sensor and the gauge goes into the failsafe mode (2 yellow led) but the boost is still there there no wastegate activation.
