Old 07-07-2009, 11:09 PM
So near. Good.
Are you planning to run 100% water, M50/W50 or 100% methanol?
Old 07-07-2009, 11:14 PM
rapidello rapidello is offline
i prefer 100% water, or 50-50....what do you reccomend?
if you want also edc16 (alfa 147 Mjet 16v)pin-out i can give you...
Old 08-07-2009, 12:05 AM
I think 50/50 is good for winter and summer.
Is edc16 (alfa 147 Mjet 15V) a common rail diesel? I like the wiring diaghram also please. It is good information for the future.
Old 08-07-2009, 10:38 AM
yes, is common rail....multijet.
my ecu is edc15, unijet common rail..... so you think that 2 injector 0,5 are good for my application?
If you send prometeus the new controller,can you pre-setting? So i can't change the trimmer set?
Thank you
If i use sometime only 100% water will be a problem?
Old 08-07-2009, 10:50 AM
this is edc16 (not for me, only for you)
CONNECTOR A
1, Cylinder 3 injector positive
2, Cylinder 2 injector positive
3, Not connected
4, Fuel pressure regulator positive
5, Not connected
6, Not connected
7, Not connected
8, Fuel pressure sensor negative
9, Not connected
10, Not connected
11, Timing sensor positive
12, Engine rpm sensor negative
13, Supercharging sensor positive
14, Not connected
15, Turbo pressure electro-pneumatic valve negative
16, Cylinder 1 injector positive
17, Cylinder 4 injector positive
18, Not connected
19, Not connected
20, Timing sensor negative
21, Not connected
22, Not connected
23, Intake air temperature and supercharging pressure sensor negative
24, Not connected
25, Not connected
26, Not connected
27, Engine rpm sensor positive
28, Fuel pressure sensor positive
29, Flow meter positive
30, Not connected
31, Cylinder 2 injector negative
32, Not connected
33, Cylinder 4 injector negative
34, Fuel pressure regulator negative
35, Insufficient engine oil pressure sensor signal
36, Not connected
37, Air temperature sensor on flow meter signal
38, Not connected
39, Not connected
40, Supercharging sensor signal
41, Coolant temperature sensor negative
42, Air flow meter signal
43, Fuel pressure sensor signal
44, Flow meter negative
45, Not connected
46, Cylinder 3 injector negative
47, Cylinder 1 injector negative
48, Not connected
49, Not connected
50, Timing sensor signal
51, Not connected
52, Not connected
53, Intake air temperature sensor signal
54, Not connected
55, Not connected
56, Not connected
57, Not connected
58, Coolant temperature sensor signal
59, Cut out throttle solenoid valve actuator negative
60, EGR solenoid valve negative
CONNECTOR B
1, Power supply from main relay
2, Control unit earth
3, Not connected
4, Control unit earth
5, Main relay power supply
6, Control unit earth
7, Not connected
8, Accelerator pedal potentiometer track 2 signal
9, Accelerator pedal potentiometer track 1 signal
10, Fuel temperature signal negative
11, Fuel temperature sensor signal
12, Not connected
13, Not connected
14, Not connected
15, Not connected
16, Not connected
17, Brake pedal switch signal
18, Not connected
19, Not connected
20, Not connected
21, Not connected
22, Not connected
23, Not connected
24, Not connected
25, Line K
26, Not connected
27, Not connected
28, Key ON signal
29, Air conditioning compressor relay
30, Accelerator pedal potentiometer track 1 negative
31, Accelerator pedal potentiometer track 2 signal
32, Not connected
33, Not connected
34, Not connected
35, Not connected
36, Not connected
37, Not connected
38, Cruise Control resume
39, Not connected
40, Not connected
41, Not connected
42, Quadinary signal
43, Not connected
44, Not connected
45, Accelerator pedal potentiometer track 1 positive
46, Accelerator pedal potentiometer track 2 positive
47, Immobilizer line W
48, Engien rpm signal output to robotized gearbox
49, Not connected
50, Not connected
51, Not connected
52, Feedback signal from heater plugs control unit
53, Not connected
54, Request to engage climate control from control button
55, Not connected
56, Cruise Control positive
57, Not connected
58, Not connected
59, Not connected
60, Not connected
61, Low C-CAN from ABS control unit
62, High C-CAN from ABS control unit
63, Not connected
64, Not connected
65, Not connected
66, Not connected
67, Not connected
68, Fuel filter heater relay operation
69, Engine cooling fan 2nd speed engagement relay
70, Not connected
71, MIL warning light
72, Main relay activation
73, Not connected
74, Water in fuel filter signal
75, Not connected
76, Not connected
77, Cruise control on/off
78, Signal for cruise control speed decrease
79, Clutch switch signal
80, Brake pedal 2nd switch signal (only for versions with cruise control)
81, Quadinary signal
82, Not connected
83, Low C CAN to body computer
84, High C CAN to body computer
85, Not connected
86, Not connected
87, Not connected
88, Not connected
89, Not connected
90, Engine cooling fan 1st speed engagement relay
91, Fuel pump relay operation
92, Not connected
93, Heater plugs engagement
Old 08-07-2009, 06:05 PM
Thank you for the diagram, it wil be very useful for the next alfa.
I have a question, I assume both ECUs are for diesel applications. There seemed to be two type of common rail diesel. what is the difference between uni-jet and multi-jet.
As regarding the trimmer of the re-configured HFS-6, you con use all the trimmers and scaling options. I just need to match the system to match and read the pulses of the diesel injectors. The pulsewidth is very short. Using water is find but use less due to the higher latent heat value than methanol.
The HFS-6 can read the following, but require some signal re-conditioning:
- Common rail diesel injector (high rail pressure - most diesel)
- Common rail gasoline injector (high rail pressure - VW, Audi, PSA)
- Gasoline direct injection with solenoid actuator
- Gasoline direct injection with piezo actuator (new BMW)
The trend is changing very fast - difficult to keep up with this new Direct injection technology.
Old 08-07-2009, 06:33 PM
Uni-jet(edc15), make a single injection on cycle,the first tipe of common rail....
multijet(using edc16) make multiple injection...so decrease diesel consumpion, decrease noise and decrease air pollution.
do you need anything else to configure controller?
i hope with the pin-out of ecu you can set up all...
Old 08-07-2009, 07:01 PM
He's next to my address, should be same. Anyway as you prefer. D
But such kind of car should take part to Brighton Speed Trials don't you agree Richard?
Rapidello non ci sono problemi a viaggiare con solo l'acqua. Il metanolo porta un miglioramento delle prestazioni ben visibile sui motori diesel, non altri. Tutto qui.
I'll be in Brighton for Speed Trials; surely be in from Friday. I'm too lazy for reserving a room now. 8 ? Flightfare are good enough to be spent online these times :twisted:... London Luton Of Course :lol:
Old 08-07-2009, 07:16 PM
The HFS-6 has a unique line for FSi and Diesel with electronic injector. It is the yellow wire on the yellow RJ45 harness.
Since we are detecting the pulse width of injector, it really doesn't matter how many injection events are there per cycle. As I read from other publications, the multi-jet has three injection events, covering idle, light load and full load.
I think I have most of the information need to get the system working for your application. I don't have one more question. Can I assume the uni-jet vary the fuel rail pressure. I may need you to locate this signal and feed it to the blue wire of the yellow harness to purpose of full signal integration. I am sure I can find the correct pinout from your previous emails.
Other basic connection such as switched +12v (ignition key position#2 - pre-cranking). It would be nice to know which pin of the ECU so that the HFS-6 can get every signal from the ECU. (unfortunately it is in the engine bay rather inside the car). I trust you can splice in the wires and provide some water proofing work afterwards.
Old 08-07-2009, 09:06 PM
if you have a problem to configure controller,i can use the component of hfs-5...or an easy system like 1s ? (now i use an 1s and is quite good)
can't you use only map sensor? without injition signal?
