#11
Re: New guy. New kit.
My kit came with the standard .8, .9, and 1mm jets.
I'm grabbing a throttle body spacer with the capacity for 6 jets. What am I gonna need to run jet/restrictor wise to him my 444whp goals knowing that we run out of factory injector at around 380whp? Should I just run all three different sized jets in the spacer? Invest in more 1mm jets? |
#12
Hello Tokay444 and Rich. LOL. I was just lurking and found your thread. I have been using Aquamist nozzles, fittings and line and I really am having a hard time recommending anything else over these jets and fittings.
Looking forward to having Richard's expertise and experience involved in the build. |
#13
Hey man! Nice to have you in here.
I tried mentioning you in my op, but it doesn't work like on MSF. |
#14
Just bumping for the question about nozzle size and amount... I also believe, as I think I have the same spacer, that the spacer he has 1/8 NPT threads for the nozzles. Can these be used to attached the nozzles to the spacer and still have everything functioning correctly http://www.aquamist-direct.com/806-3...et-adaptors-r/ |
#15
Been a while.
Build it progressing. Head is out being rebuilt and ported right now, and few more parts have come in. Remote oil cooler. R-comps. Throttle body meth spacer and second oil catch can.
The Seals Last edited by Tokay444; 02-05-2015 at 04:49 PM. |
#18
The only thing missing on this build is the CPe Atmosphere downpipe :P
#20
I can almost see end product. Doing well so far.
