Old 17-12-2014, 03:15 AM
Matutino Matutino is offline
Default HFS-6 boost compensation future
I have mine hooked up to IDC but, reading the manual it states that it also has boost compensation.
How does it work? How can I take advantage of it while following IDC?
Matt
Old 18-12-2014, 12:56 PM
Default Re: HFS-6 boost compensation future
Boost compensation:
If boost signal is available from the factory maps sensor, you can use this signal to offset the drop in spray volume due to manifold pressure increase.
Old 19-12-2014, 05:53 AM
My E36 M3 does not have a factory map sensor. Im using the OEM DME for tuning. Would adding a GM 3 bar map sensor do the trick to take advantage of the boost compensation?
I can pick up a 5v signal and hook up the other end of it to the HFS-6.
Would this work while following IDC?
Old 23-12-2014, 04:59 PM
Anyone can answer my question to Richard?
Old 31-12-2014, 01:54 AM
Richard, any luck replying top my post. Is it worth it to add a 3 bar map sensor to my set up?
Old 01-01-2015, 09:03 AM
As long as the span is 5V, any map sensor will work.
Old 02-01-2015, 03:15 AM
Yes, its a 5v map sensor.
I guess my questions is if there is a benefit of using it or not
Old 10-01-2015, 04:49 AM
Would I see any performance benefit or not by adding it a map sensor?
Old 14-01-2015, 06:01 AM
Any luck to answer my question. Is it worth it to add a Map sensor, would it add any performance? Seems worthless if you are already following idc
Please let me know
Old 14-01-2015, 08:38 PM
If the system is based on IDC, add a map sensor will not be beneficial. If your fuelling is good, the water/meth flow will follow.
