Old 31-03-2016, 08:11 AM
Default Re: Direct Port EVO IX rs HFS3
The 5th jet (post IC) should be the air cooling work. The port jets will do the the combustion chamber cooling.
Old 31-03-2016, 08:57 PM
Iguanapeluda Iguanapeluda is offline
Richad, I have a question.
If I put the jet in the place that you are tell me...is possible that the water spray crash with the intake and condensed water?...
It will be better install the jets in the final of the runners opposite injectors with an angle like the inyectors?
Thank you!!!
Old 31-03-2016, 11:08 PM
parmas parmas is offline
Condensed water will eventually continue cooling the charge even when no water is injected
Old 31-03-2016, 11:49 PM
The mass of air flowing across the spray will be around 2kgs/min. If you are injecting 100g/min, what are the chances of the spray hitting the opposite wall?
Answer, very little.
The aquamist jet has a spray angle of ~80 degrees. You cannot angle the jet too much or risk spoiling the spray pattern. If this happens, you will loose 25% of the atomisation. If you want a good atomisation, point the jet against the air flow.
Old 01-04-2016, 12:54 AM
It doesn't matter. If you think about it, some water will make it's way to the intake valves and sit there waiting for the next engine cycle.
Old 03-04-2016, 05:06 PM
Well....finally...
What do you prefer...
In this place? With this installation...
Or in the initial place? (Number 1 place)
Old 03-04-2016, 05:39 PM
90-degree is the angle I recommend and the easiest. But you can try other angles if you prepare to make the jet adaptor to fit properly.
Old 03-04-2016, 05:49 PM
Ok ok, I will put 90š in the "1" place.
Thank you Richard, I will inform for the updates with the installation.
Old 05-04-2016, 08:44 PM
Well...jetīs installed in the only place that I can put...
And the fifht jet:
Old 05-04-2016, 08:52 PM
Don't use these clamps with boost.
