Old 18-05-2004, 04:21 AM
vica153 vica153 is offline
Default Controlling the aquamist system.
Im about to install a turbo on my ford focus and plan on installing an Aquamist system soon after. My question is what aftermarket ECU works best to control the turbo and aquamist systems? I had my eye on the multi-position FordCHIP, but i'm not sure if that can control the Aquamist system. Anyone know if it can?
I read about someone who installed Prophec-B boost controller and then a daughter chip to control the aquamist, that sounds like a real pain. What do you all think would be the best/easiest way to go? Any info will help a lot.
Thanks,
Ken :arrow: :twisted: :arrow: 8)
Ken
Old 19-05-2004, 12:13 AM
If the engine management you select doesn't have a seperate injector driver available and unused, I would look into the system 2d this will approximate the injector duty cycle to give you a progressive water flow in line with your fuel flows.
Ed.
Sponsoring Board Vendor
