Old 14-12-2011, 12:40 AM
lil powell lil powell is offline
Default Re: 997TT issues?
So far, all test results are positive.
The next test will be getting the two jets out of the charge pipe and watch the spray pattern and bars on the gauge, using the "SYS" test jumper. Don't do it more than a few seconds at a time.
PLease post results.
I pulled both jets out of the charge pipe, when I jump the "SYS" the gauge lit half the bars. But when I went to look at the spray pattern, the water shot out far and in a straight line like a super soaker. There was no cone pattern just a high pressure stream.
Old 14-12-2011, 08:33 AM
Thanks for the update...
I suspect the jet with a straight spray does not have an internal spinner or it is not screw down properly. Check the internal. Has the jet been serviced since the installation?
During this test, what is the "SC" set to?
Until this problem jet is working as designed, we cannot set the bargraph of the gauge properely.
The system appears to be work as it should besides the jets.
