#11
Re: HFS-3 failed the driving test
Only a sealed container direct from factory, not a re-capped container for a local supplier.
#12
I plan to run 3 jets past the TBS, I think that it will look much tidier to use a distribution manifold than to utilize 2 X T fittings. Do I need a check valve? if yes then should it be one between the FAV and the manifold or 3 between the manifold and each jet? Last edited by TJ; 19-07-2012 at 11:36 AM. |
#13
Will there be a pressure differential between the jets during boost and after lift-off? If it does, you need to have a checkvalve to isolate between them. This is to prevent the liquid being drawn out of the hose between the jets.
If you can keep the between the jets and FAV as short as possible, you may not require a checkvalve or checkvalves.
#14
