BMW Early N55 HFS4 v3.1 installation (unfinished)
Hi Richard,
I've emailed you about step two of the installation and haven't heard from you since Recall: I purchased a new HFS4 v3.1 kit from you, you emailed me the step 1, which is moving those jumper to x2.5 IDC pre scaler. Been emailing you about step 2, which I assume is cutting 3 and jump 2 for MAP sensor(cut 3.5 bar, connect 2.5 bar)? I have a 2011 335i N55 btw... Joey |
Re: BMW Early N55 HFS4 v3.1 installation (unfinished)
Joey,
I just checked all my in boxes, no email form you, if the email address begins with joey.... Can you pm me the date or your email address, I have to make sure it is not arrested by the spam filter. I always answer my emails within a few days.
Send you an email via the forum.
got it this time, I will reply.
Still haven't got your reply.... I assume you lost me again.
Why don't we talk here? Step one is to set the IDC jumper to x2.5. Whats next step? |
I will talk here from now and stop emailing me.
OK, lets start from the beginning so we can do it properly:
1. the power? 2. Tuning box or standard?
2. Max boost 21 psi (factory 2.5 bar MAP sensor) across the mid range (3000 to 5000 or less), trying to raise it at the redline so I get more "HP" instead of high torque only. still tuning it 3. Tuning box or standard? I'm using Cobb ATR |
Here is diagram for the HFS4-v3.1. Please check beofere moving on.
Yup this is the sheet we used for installation.
