Old 19-09-2016, 07:14 PM
ARMY ANT ARMY ANT is offline
Unhappy Need some help
I need to find out if i can replace C16 with a aquamist system.
If so which system and how many injectors?
I'm running an EVO 8 with 2150 cc injectors.
93 octane and C16. Do not wish to use E85.
Aquamist can you help me ?
Old 25-09-2016, 11:57 AM
rotrex rotrex is offline
Default Re: Need some help
IMHO they can help you.
I would suggest direct port injection.
4 nozzles right before the fuel injectors in the straight section of the plenum on the top side.
Flow level rule of thumb 1.5ml/min per HP.
If those 2150cc injectors is total flow over all 4, then you are likely in the 350 to 450 HP region. So jet wise you could start with 4x 0.4mm C jets or go right to 4x 0.5mm jets.
You need to be able to fully remap the WOT mapping to take full advantage of water methanol injection. Use a 50:50 mix per weight, so about 1l liter of methanol mixed with 0.8l of distilled water.
If your injectors are 2150cc/min each, you need to talk to specialists anyhow.
Old 27-09-2016, 12:59 AM
Thank you ,but at this time i'm at 500whp plus on pump gas.
this why i need help. where is Team Aquamist to save me with this problem..
I want to use Alcohol...
Old 27-09-2016, 07:52 AM
If you are not going to use E85, What are the reasons for the 2150 injectors? What is your power target?
Old 01-10-2016, 05:39 AM
Just looking to stop using C16 on the second program.
when i use the C16 and go to park for a few weeks i have to drain the fuel, so by going with Aquamist i know longer have to drain the fuel.
Old 01-10-2016, 05:47 AM
Horsepower I'm running 665whp C16 .
Looking for the same or better with Aquamist system on denatured alcohol .
I have faith in the Aquamist ...
Old 03-10-2016, 10:54 PM
You are probalby looking at 1200 to 2000 ml/min of water methanol mix at this power level.
Install a BIG tank for track work.
That is some serious flow for some serious power :-)
You might consider getting a air assisted spray system such as what riceracing is selling.
The work best with high boost and high flow.
Otherwise I have good experience with direct port injection with 4 nozzles right before the fuel injectors.
Old 04-10-2016, 09:16 PM
Thank you ... i'm thinking on the direct injection system will be the best system for me with the large tank , but what injectors should i start with ?
Old 06-10-2016, 10:13 PM
from the aquamist webshop :-)
