#11
My IDC's are between 80 and 90% depending on boost levels.
I run my injectors sequentially and don't believe there are any additional drivers, however there is a nitrous feature that maybe I could use somehow?? Has that been done by anyone? The rules state that I can only use straight water for this event. I will use alcohol after that. How difficult are these systems to tune in? Time is a big issue! Is there much of an advantage in using straight water or do the real benefits happen with alcohol or methanol? I would like to build a system that would support 1100bhp. Is that what you are thinking also when suggesting those components? How much additional boost could I apply if using straight water? Thanks, Chris
http://www.forcedpsi.com |
#12
The benefit of straight water alone is going to be dependent on the AFR that you would need to use to suppress knock.
My assumption is the psi's previously listed are within the efficiency range of the turbos. Is there a fueling and timing combination that would permit you to run 20 psi on pump gas at all without knock? I know it wouldn't be near the 1100 hp you currently get with race fuel but could you do it for instance with a rich fuel setting and retarded timing? If you can, then you will be able to tune back up as if you were using race gas. First tune the car with its rich fuel settings and retarded timing to permit a knock free (albeit not powerful) tune. Then add the water injection and start leaning the fueling. Your power will start increasing. Once you are happy with the AFR power and water injection is suppressing the knock that would otherwise occur - then you can start looking for MBT. It will likely be about a degree more advance than you were getting with race fuel. Time to tune wise - you are probably in good shape. Clearly you have enough experience with your setup that you have a good feel where to go run to run. To start with think of when the water injection is engaged you have just switched from pump gas to race gas. That is in general terms it will be slightly different. The nitrous switch is probably binary and not pulse width. If it is pulse width and can be mapped then you could use it. If it is binary on/off then you could use it to drive an fia2 system which would match your water flow approximately relative to your fuel flow. This will not be as optimum as mapping water to your torque/cylinder pressure curves but it will be a big help in moving you towards your power goals while suppressing knock. Based on another post which brad responded to - you may even be able to do it with only one shurflo pump instead of two, brad could answer that better. With Aquamist pumps you would definitely need two and some accumulators to achieve your desired flow. Either way plan on a few jets. The f-body below has twin turbos with no intercooler. It is using two Aquamist pumps and by my best guess of the routing 6 jets. Richard could tell you more about this customer's results but it was impressive. He previously had a huge front mount setup with no water injection. |
#13
Correction, two Shurflo pumps.
The car uses 6 litre of fuel per minute and 2.7 litre of water if I remember right. Power between 1300-1500HP. Two HSVs and managed by a Autronic computer (I think) - it also has WI mapped for staging. The Guy took away the intercooler in favour of water injection:
#14
Who said you can't drift an f-body?
#15
That doesn't look like drifting above. It looks what happens when you try to put 1300hp+ to the ground. :shock:
