Old 30-08-2010, 04:21 AM
jmargo jmargo is offline
Default Re: Hfs-3 bmw e-36
Looks like I can't leave anything alone....decided to add a pre SC nozzle in my spare thermoplastic intake. This is the 0.3 from the volute which now has a 0.4. Now that I have four nozzles I think the four port manifold will go in place of the three port jet manifold.
Old 10-09-2010, 06:40 AM
So I am sure Jeff is sick of me changing everything around. He was nice enough to fab up a bracket and sold me the four port manifold for a cleaner install. I now promise that I am done......
but I am thinking that it would look alot better with AN lines.
Old 11-09-2010, 05:23 PM
Well technically I did not change anything....
New offering I just picked up from Howerton engineering. Its a basic switch to trigger the WI anytime you want to cool things down. Basic,simple and clean !!
Old 11-09-2010, 06:46 PM
Wow, you have the remote spray button? This is for staging on the drag strip?
One more toy for you. The new HFS-3 has a new function, your can set the DC% of the spray when you press the button.
Old 11-09-2010, 07:09 PM
Howerton Engineering
I had glossed over that. We can set it up so the test jumper sprays a certain DC instead of 100%.
Old 11-09-2010, 08:41 PM
Is that on the board or does it need to be "flashed" ?
Installed and tested !! I am thinking its use will be more for cruising down the highway, having someone pull up to me, downshift to bring up the revs, pre-spray to cool things down and get the air out of the lines then WOT.
Old 03-10-2010, 12:20 AM
Because I have a nozzle in the intake I had siphoning so I added two checkvalves....
Old 03-10-2010, 10:47 AM
You have left no stone unturned. I always enjoyed lloking at those nice images you posted.
Old 04-10-2010, 06:53 AM
Dust Dust is offline
This kit is beautiful, as is the car. Could you PM me and let me know how much you have in the system?
Old 05-10-2010, 06:19 PM
Well that is easy...
HFS-3 plus Howeton tank (group buy)
4 Port manifold
2 extra nozzles and adapters
4 90deg fittings
2 check valves
1 pump swivel
1 test circuit
= just about $1000 USD
