Old 27-01-2016, 12:19 AM
FI_Rubicon FI_Rubicon is offline
Default Re: AUX input - IAT or WideBand o2?
This is the error of the manual, needed correcting. WBO2 should be grouped with IAT.
Grouped? I do not understand. Do you mean grouped electrically via the circuit board you showed me?
Can I assume WBO2's 0v output is lean and 5V output is rich?
Looks like not. From the Innovate LC-2 user guide. And I am not sure I can reprogram it to be the inverse.
"Analog Output is configured as 0 volt = 7.35 AFR and 5 volts = 22.39 AFR"
Anyway, this is not sounding useful for my setup. I will probably just stick with the IDC as the trigger with IDC and MPS as the reference signals.
Old 27-01-2016, 06:56 AM
Grouped means the signal inversion.
- IAT sensor voltage goes lower as the temperature gets higher. (Inverted)
- EGT, WBO2, boost goes higher as the danger zone is approaching. (Non inverted)
This means the user manual is correct. No need to re-configure. You can not use the WBO2 signal to compensate and boost drop failsafe.
Remind me what car do you have.
Old 27-01-2016, 01:52 PM
point78 point78 is offline
I have the same WBO2 as the OP.
Are you saying that the WBO2 cannot be connected to trigger a failsafe and drop boost? (if 0V is rich and 5v is lean?)
or are you talking flow compensation?
Old 27-01-2016, 03:07 PM
You can do both at the same time.
Even the WBO2 signal is inverted, ie 0v=lean and 5v= rich, it can still be done by solder link on the HFS4-v3.1.
Old 30-01-2016, 09:48 PM
I just ordered my system and will be making this connection as well.
Old 30-01-2016, 10:59 PM
Thanks for the order.
Are you good at soldering?
Old 31-01-2016, 12:16 AM
yes.
proof (laser replacement on my Denon DVD player):
https://www.youtube.com/watch?v=wjPkjHvHMPo
Old 31-01-2016, 10:17 AM
Impressed!
Old 01-02-2016, 06:37 PM
Thanks but be more impressed that I resurrected a good old CD player for ~$16USD. Desoldering the anti-static shunt was a breeze.
So what bit of soldering are you alluding to here?
Are you referring to the wire connection between the WBO2 unit (brown wire of the Innovate LC-2) to the HFS-4's blue wire in the green harness? I think this is just a direct connection here unless you are suggesting something more..??
Old 02-02-2016, 12:16 AM
Linking two pads with solder, this might seem simple to you. Believe me, I have seen some real disasters of epic proportions.
