Old 14-03-2016, 11:56 PM
Maktech Maktech is offline
Default Re: Help please,HFS 4 V3 wiring diagram for E63 AMG
Can you confirm the engine does not use direct fuel injectors.
I don't know how to confirm that.
If you know , could you describe me please ?
Old 15-03-2016, 12:00 AM
I don't think it is.
Try use the red and green wire of the grey harness first.
Old 15-03-2016, 02:16 PM
I'm sending the jumpers positions with the photo ,
Can you check them if they are correct...
The pump still works when we start the engine ,
doesn't pump any water , but we hear the sound of the pump.
Old 15-03-2016, 05:35 PM
The photo you sent is not easy to view. Can you take a better Hi-res pictuire? The entire circuit board please.
You wrote:
"When you mention the pump still work after your start the engine?"
What exactly.
do you mean by this?
Old 15-03-2016, 05:40 PM
I mean , when the engine is at idle , Aquamist's pump working noisy ,
it is not injecting anything but it is working as if it will explode 😱😱😱
Old 15-03-2016, 05:43 PM
Here are the jumpers
Old 15-03-2016, 06:16 PM
The pump should not come on when idling. Is this a brand new system?
I need a picture of the entire circuit board, you jet posted the same picture but bigger.
Old 15-03-2016, 06:30 PM
Here is the photo of the circuit :
Please watch the video for seeing the pump how is working at idle ,
http://youtu.be/SCX2m5un5S8
Old 15-03-2016, 11:03 PM
The pump should not come on at idle.
Can you take a picture of the controller with all the cable plugged in. Again a hi-res picture please. Like to check your plugs.
Old 16-03-2016, 11:56 AM
This is the controller
