Old 23-10-2013, 08:36 PM
Default Re: Wiring issue
with the engine on?
Old 23-10-2013, 08:44 PM
bulldogface bulldogface is offline
14.21V with engine on
Old 23-10-2013, 08:59 PM
Was the molex plugged into the H3 during the measurement?
Old 23-10-2013, 09:05 PM
yes. red into switched 12v, white and black separately grounded, purple wire is not used.
Old 23-10-2013, 09:09 PM
Lets go a bit further, check the soldering on each pin of the fuse holder. The one nearest the edge of the board is directed linked to the red molex cable. It should have a 12V there. Also check the soldering quality of the molex connector.
Old 23-10-2013, 09:39 PM
visually, all soldering is ok. on coonection pin solder point for red wire to control module voltage drops to ca 8.8V. on fuses, measured at solder points from bottom side of circuit board i've got 0.25V both sides.
Old 23-10-2013, 09:43 PM
Unplug all harness except the molex.
Can you measure the voltage between the red wire and the 5A fuse, either side.
Old 23-10-2013, 09:47 PM
One more question, what colour is the circuit board?
Old 23-10-2013, 09:53 PM
board is dark red, it is v3 control unit. running to car to measure.
Old 23-10-2013, 09:58 PM
I would take the circuit board out of the car and do it in front of the computer with a meter. you don't need to plug it into the molex.
