#21
Re: Hfs-4 wiring for Audi B8 s4 3.0 (2009-2013)?
No, it doesn't need to come on at all. If it does, it has reached its ceiling.
Very nice looking work!
#22
One step at a time, and update every stage if possible..
Can you measure the voltage of pin 2 when the idle and WOT?
#24
What do you think about adding a single .3 injector pre blower? just for air cooling, would it work ok with my direct port setup? I would jut run a line off the end of the 6 port manifold where its currently plugged. |
#25
There is no harm putting a 0.3 jet. Anything to keep the SC casing/gearbox cool is a plus. It will of course cooling the air as well.
The extra port on the 6-port manifold is ideal for that. An inline checkvalve would be advised if the hose is long.
#26
Hey Richard, I have inherited this project and had some more questions about failsafe.
It looks like the bypass valve that was mentioned before is just a motor and an angle sensor. Can the HFS-4 be wired to use this somehow? image ru Last edited by MiztahSparklez; 04-09-2017 at 10:52 AM. |
#27
I think it may work.
You need apply a 5V bias at pin 2 or disconnect pin 1. Need to experiment.
#28
Ok let me measure the voltage on pin 2. I'll see if I can manage to log the bypass from the ecu to match up.
I can also just disconnect pin one to see what happens. Do you know what the corresponding pins are on the ECU? Otherwise I'll test continuity of whatever color wires I find. |
#29
I will email it to you.
#30
Hey Richard,
Did you send me anything? I didn't see it in my email if you did. Thanks |
Thread Tools | |
Display Modes | |
