Old 16-03-2016, 07:14 PM
Default Re: Help please,HFS 4 V3 wiring diagram for E63 AMG
Is this 0.08 ohm?
What resistance range did you use?
Old 16-03-2016, 07:22 PM
Maktech Maktech is offline
This is a RJ connector, see the gold fingers between the plastic compartments?
The RJ connector seems alright
Old 16-03-2016, 07:27 PM
Is this 0.08 ohm?
2K ,
shown in the photo
Old 16-03-2016, 10:17 PM
So far so good.
Can you measure the blue wire of the blue harness against a chassis ground, such as the cigar lighter ground.
Old 16-03-2016, 10:20 PM
It would be better if you can use the 200 ohm range.
Old 16-03-2016, 10:30 PM
Can you also measure the resistance between the blue and black.
Old 17-03-2016, 10:07 AM
There is no value between blue and black ,
No value for the blue wire (grounded with cigar lighter)
Old 17-03-2016, 06:30 PM
This is good news, the blue harness is in perfect health.
I like you you do some tests on the controller.
There are two rows of 15 test points. Systen ground is on the bottom left of the test points. This is where the black probe of your meter should go.
With the system at "per-crank" key position, please measure the voltage at:
TP4
TP5
TP8
TP11
TP15
TP16
TP17
TP18
TP20
TP23
TP30
You can use the 20V DC range.
Old 17-03-2016, 06:59 PM
Here are the results :
TP4 : 12.40
TP5 : 12.41
TP8 : 12.18
TP11 : 8.96
TP15 : 4.96
TP16 : 7.40
TP17 : 1.95
TP18 : 2.98
TP20 : 2.04
TP23 : 12.44
TP30 : 0.02
Old 17-03-2016, 07:29 PM
Thank you very good infos
Now switch the gauge on still at pre-crank key position. Same TPs.
Sorry for taking so long trackdown the problem, it one is most unusual.
