Choosing the right nozzle...again
Hello to Everyone,
I just installed an Aquamist 1s system and would appreciate help on the most applicable nozzle for the following setup: --Miata 1.6 L with a Jackson Racing Supercharger boost at 6Psi(.4 bar) --Timing set at 12 deg BTDC --Stock fuel injectors rated at 220 cc/min, --An auxillary pressure regulator that is indexed to boost and at WOT --is supposed to raise f/i pressure to the injectors at 80 psi. I was trying to decipher the Aquamist graph to no avail as I can't figure out the flow rate for a .5 nozzle at 100 psi(7 bar). I am using a .5 nozzle right now. With an Aquamist 100 psi race pump and with the stock injectors and AFPR what % water am I currently injecting. Thanks for your help. |
Thread Tools | |
Display Modes | |
