Wi on turbo gsxr-1000
Hi, I am new to water injection and looking for a good calculation on what jet I should be using. I've read some of the posts and some of you guys seem to know whats going on. I'm running a 1S system on a GSXR-1000 Suzuki the turbo set up is a non-intercooled garrett t-28, I've had it on for 2 yrs running between 5.5 and 7.5 psi. Pump gas (93oct) is fine at low boost I mostly run a 50-50 mix withSunoco 110. Low boost usually dynos at 215-220 at the wheel at 8 lbs we hit 237 all sae without WI. Its an everyday driver I take to the track on weekends but want start running up to 9lbs for topspeed runs to see how far into the 200's I can get. I'm expecting around 245hp at the wheel. the motor is stock 12:1 comp, injectors are 300cc/min (I THINK) I am not sure how to calculate which jet wont be to much. From what Ive' seen so far I think a .4 or .5 is what I need, leaning towards the .4. I only carry 14oz's of water and the pump seems to empty it pretty quick. Any help is appreciated!!
Please call velocity racing, they know more on WI bike than anyone else.
Tel1: 866- 4 -SPEED Tel2: 954 452 9918 Contact: Barry Henson / Ken
Thanks Richard, I talked to Ken they run a .5 . Well see what happens as soon as the wheather comes around, expecting snow on Easter. It really sucks here!!
