Old 13-05-2013, 09:04 AM
pluto pluto is offline
Default HFS3 Ver 2 onto 8L Audi S3 1.8 20VT
Hi Richard ,
Greetings,
Perhaps you can assist me
The ecu in question is ME7.5 Bosch
Thus far
I have linked the Injector negative to the green wire
Map sensor pin 4 to blue wire
Red wire to injector + ive
All of the above on the ECU cable.
On the rear end of the board ,
PWM - ive linked
Multiplier is at 1x
IDC is linked
Questions :
1. I want to have IDC as the primary , with MPS as the trigger - is this correct ? If so , which do I link on the back and which to I jump on the front ?
Old 27-05-2013, 02:23 PM
Default Re: HFS3 Ver 2 onto 8L Audi S3 1.8 20VT
First of all, is your engine car a direct injection type?
It is better to put the red wire to a "pre-crank live" 12V switch rather the injector (+), it can be quite noisy there.
You only need to link the back if you want the system to run 70% IDC / 30% MPS. Otherwise, leave the solder link option.
Old 28-05-2013, 02:54 PM
Richard ,
\Greetings,
Normal port injection using the EV6 injectors if I believe.
So I have linked the back on IDC , is that correct ? Yes , I want to run the 70 % IDC/ 30 % MAP . In your expert opinion , would this set up give you better control ?
On the top side of the board , IDC is jumped as the trigger .
Thank you for your reply
Old 28-05-2013, 07:42 PM
One more question, are they low impedance injectors? If they are you need to use green harness, but leave the gain as x1.
Old 28-05-2013, 08:57 PM
Hi ,
These are the normal high impedance injectors , like those found on the 8L A3 / Golf 4 GTI / B6 Audi's ect.
Old 28-05-2013, 08:58 PM
Originally Posted by pluto View Post
Richard ,
\Greetings,
Richard ,
Greetings, any feedback on this ?
If I recall , the board came out of the box linked to IDC
Old 30-05-2013, 08:40 AM
70 % IDC / 30% MAP is more suitable for stretched factory turbo where thermal load is more concentrated at the spool up area. Having more boost related delivery will help combating stress related knock. Often resulted in timing cut and power drop.
The configuration is totally reversible, no harm in trying it out.
Old 06-06-2013, 04:39 PM
Quattro Quattro is offline
Richard ,
As usual we can count on you for the awnser ! Thanks ,
So to recap , please confirm
I want to use the 30 / 70 (map/idc) so,
Rear of Board
Only IDC linked or do I link both or unlink both ( I couldnt understand your explanation , sorry)
Front of board - independant of the rear , I choose map as the trigger to get injection during mid spool or peak boost. Its a small frame turbo so it spools hard and fast.
Old 06-06-2013, 07:44 PM
Here are the possible combinations for the under-board solder mods:
1. IDC linked ............. 100% IDC (factory setting)
2. IDC + MPS (solder linked) ............ 70% IDC / 30% MPS
3. Cut IDC link + MPS (solder linked) ............... 100% MPS
Old 11-07-2013, 04:58 AM
dscline dscline is offline
I have a question about this... is there any way to change this ratio, such as using resistors for the links, or some other trick? Is there any way to get to a 50/50 ratio, or some other ratio that puts more emphasis on MPS (other than 100% MPS)?
