#11
Re: Gain setting issue -HFS-3
Ahh I see. I saw his projects in this forum sections. Russian tuners are getting more and more attached to Aquamist products )))
Richard, could you pls. let me know which is the maximum gain you may set with gain trimmer? Is it x4 to IDC or I got it wrongly? |
#12
The gain trimmer is approximately 3x. But it will only be effective from the trigger point. If you want to increase the IDC signal. it is best done on the multiplier on the underside of the circuit board. x1 (default), x1.5 and x2.5.
#13
OK, understood. Thanks Richard!
#14
what car is the system in?
#15
Opel Astra OPC (http://www.aquamist.co.uk/vbulletin/...ead.php?t=2393). Now with gtx2863 turbo.
