Old 04-09-2016, 05:43 PM
alexanderfitu alexanderfitu is offline
Default WMI for M275 S65 AMG
Hi all
I have had experience with Methanol/water injection on my previous vehicle, a CL55 AMG Komp. I ended up putting 2 400cc injectors after the intercooler and it did work well. The engine failed on that car (failed oil control rings on all cylinders, probably due to a poor remap), so on wards to better things!
I am considering the aquamist sytem for my S65 AMG.
This engine has a different intake layout, considering its turbo charged, it looks like this:
This is somebody opinion of meth nozzle location. It is just before the throttle body and before the intake manifold. My worry with this location is that some cylinders will get less W/M than others?
My primary goal is for air inlet temperature reduction.
Additionally, the car will be tuned for approximately 700 bhp @ 25psi. Will I need to run two nozzles?
Thanks in advance!
Old 04-09-2016, 06:11 PM
Default Re: WMI for M275 S65 AMG
Further info, here is is the inlet manifold removed from the car:
Old 04-09-2016, 07:08 PM
Additionally, is it normal to see a reduction in boost pressure when injected after the IC?
This post on a MB forum, shows somebody having this issue on a 600 engined car (same engine). The meth in that setup is being injected before both the MAP sensor and the air intake sensor.
Wondering why the boost pressure drops? Surely a reduced charge temperature should increase boost pressure?
Old 14-09-2016, 04:38 PM
Do you know if reduction torque in the same RPM?
Most engine managements limit the power when excessive torque is detected. They just partially shutting the throttle, hence boost reduction.
Old 14-09-2016, 04:45 PM
That's a good point, its possible that he is hitting a torque limiter in the map. The gearbox also limits torque output of the engine.
Can you recommend nozzle size for my application?
