Old 05-06-2023, 07:38 PM
sbrunthaler sbrunthaler is offline
Question FAV making noise but not letting fluid pass
Hi,
after my car was not driven for app. 5 months, the HFS-3 shows an error.
I checked the nozzle, works fine, and the pump works as well.
There is pressure before the FAV, but the hose after the FAV is dry.
The FAV makes noise, so I guess the valve works but is somehow clogged.
Can it be cleaned or repaired somehow, or do I need a new one?
Thank you!
Regards
Stefan
Old 19-06-2023, 11:55 AM
Default Re: FAV making noise but not letting fluid pass
When I disassembled it, I found that the small sieve inside is clogged.
I will try to clean it, but I have no idea where the contamination came from.
Regards,
Stefan B.
Old 09-07-2023, 06:59 PM
Cleaned it, put everything together, and now the flow is fine.
But the pump head has a small crack, so I need a spare part.
Always empty the system for cold periods if you park the car over winter...
Regards,
Stefan B.
