Old 12-08-2005, 10:19 PM
sabreofsd sabreofsd is offline
It is the most simplest of things that causes the most problem. How far are you away from him (distance wise)?
About 30 minutes or so
Very odd on the Hydra not detecting the ground. What is the DDS3 grounded to vs. the relay? Even if the resistance is about the same, you'll have varying grounds depending on what else is grounded to that point. Just some thoughts
Sabre (Julian)
The P in DCAWD
www.dcawd.com
WRB 04 STI: 97.73% Stock
More info here
