Old 31-03-2004, 10:48 PM
Nenad Nenad is offline
Understood, opposit side from what I said. Between those pulleys is minimal gap, millimeter or so.
"They can order any color...as long as it is black"
H.F.
Old 01-04-2004, 01:12 AM
Well, nice try.
One other possibility is to put another pulley in front of the water pump pulley and use a second belt to drive the s/c. The original belt (shorter) can now be used as it is unnecessary to go over the s/c pulley.
Old 01-04-2004, 01:20 AM
Can these pics help to better explain where should be extra pulley fitted?
H.F.
Old 01-04-2004, 01:47 AM
Try to draw the second pulley in front of larger one.
You will also need to put another pulley in front of the supercharger or move the s/c forward. In most cases, you should be able to obtain a longer s/c nose.
Old 01-04-2004, 08:03 AM
Good idea, didn't tought that way at all.
H.F.
