Old 03-10-2011, 03:58 PM
m.s4 m.s4 is offline
Default Re: Failesafe question
Jeff,
I think m.s4 has v1 circuit board. DFS jumper link is not available.
m,s4,
You can do several things:
1. Widen the WL and WH window
2. Set the F/S delay trimmer to fully clockwise.
You are correct, I have the first version.
I already have the WL and WH window widened and it still interferes occasionally on the track.
I will play with the timer a bit and see if that helps. There's no way to keep it from clipping boost? I might need to do some re-wiring then to make it so the failsafe is easily removable.
Old 03-10-2011, 09:44 PM
Try the delay trimmer, it is very effective, filters out all the spikes.
