Old 09-04-2014, 05:48 PM
andysharp andysharp is offline
Default Re: peugeot 207
just replied to the PM Rickk207.
we found the 0.6mm injector was the best option, the 0.7mm and 0.8mm were putting in too much to the small 1.6l engine and we were loosing power, with the 0.6mm it works perfect.
as for the wiring.... its definitely a job for a Peugeot specialist!
Old 09-04-2014, 06:12 PM
Rickk207 Rickk207 is offline
ah oke i was thinking about going to the nearest Peugeot garage and ask them.
but also found the wiring of a r56 mini cooper s, its the same engine and the diagarm of his ECU looks the same as the 207.
Old 09-04-2014, 07:11 PM
I believe it is the same, But do check first.
Old 09-04-2014, 08:01 PM
Will do, would let you know.
Old 09-04-2014, 08:14 PM
If this is the case, I can make a new drawing for the 207. Look forward to your findings.
Old 11-04-2014, 06:50 PM
I need help with the nozle...
what type of thread is it? its M8 but its other thread.
btw, the diagram is the same from the mini and the 207
Old 11-04-2014, 07:17 PM
Andy sharp (above) mentioned 0.6 am 0.7mm. I think it is pretty accurate. The systemn come with 3 jets, so go for 0.5, 0.6 and 0.7mm.
It is not so critical for the jet sizes as the system and adjust flow electronically.
The system comes with jet adaptor (1/8NPT). If you don't use it the jet is M8 x 0.75mm
Old 11-04-2014, 07:43 PM
Found it thanks.
The set was deliverd with 0,9 0,8 and 0,7...
But i traded the 0,9 with a 0,6 so thats fine.
Tomorrow gonna finish the install.
Old 11-04-2014, 08:10 PM
Who did you buy the system from?
Old 11-04-2014, 08:15 PM
From Biesheuvel Autosports, here in the Netherlands.
http://www.biesheuvel.nl/
http://www.biesheuvel.nl/product/148/hfs_2v2
