Old 02-03-2016, 12:19 AM
boostsys boostsys is offline
Default Re: FAV not working from controller
I can do this tomorrow.
Old 02-03-2016, 06:06 PM
Resistance between red and black pins - 0 Ohm.
Old 02-03-2016, 08:57 PM
This with the FAV plugged in?
Old 02-03-2016, 09:02 PM
Yes, FAV plugged in
Old 02-03-2016, 09:10 PM
0 ohm is a short circuit. The FAV should have a resistance of 12 ohms. What resistance scale were you on?
Send a picture of the reading.
Old 02-03-2016, 09:23 PM
Oh, sorry. There is no resistance between red and black pins.
Old 02-03-2016, 09:28 PM
OK.
Measure the resistance between black and blue
Also can you check the inside of the FAV connector. I there must be a loose joint inside.
Old 02-03-2016, 09:43 PM
Inside of the FAV connector red and yellow, black and blue wires soldered together
Old 02-03-2016, 09:48 PM
Are they soldered onto the the two connector's contacts securely?
Old 02-03-2016, 10:12 PM
I will have checked it tomorrow.
Maybe red wire have a problem, because between yellow and black (blue) resistance 13.5 Ohms.
