Old 02-05-2018, 09:25 AM
trmurphy21 trmurphy21 is offline
Default Re: Problems with set up
i'm going to try connecting the black and red wires somewhere else. i'll try the heater fan controls they are on key second position. i'll let you know how i get on
Old 02-05-2018, 10:36 AM
also check the red and green wire of the grey are not reversed at the fuel injector splice.
Old 02-05-2018, 01:09 PM
will do thanks. i have checked these i'll double check again. made the mistake of using a phase tester instead of a multimeter on the green injector wire and engine spluttered a bit (opened injector fully) and getting between 2-4 volts on the blue map sensor (will confirm)
also just to check, what readings should i be getting on the 2 signal points on the pump relay with the sys jumper in and out? meter points: black to earth in boot , red to 2 points or meter points: black to blue , red to red?
cheers
Old 03-05-2018, 07:23 AM
Can you measure pin16 while blipping the throttle.
Old 08-05-2018, 02:53 PM
hi Richard i've been away for a few days i check this later. thanks
Old 12-05-2018, 03:37 PM
Hi Richard I swapped the red wire for the controller as you suggested and it worked!!!! System is priming now putting it back together to take it for a spin make sure everything is OK. The wire I used turned out to be the low fuel light wire and wasn't a steady live
Old 13-05-2018, 06:03 PM
Thanks for the update.
Tags
priming, problem
