Old 18-06-2006, 11:18 AM
sdminus sdminus is offline
I would expect to see a drop in power by that amount. I would be tempted to get an egt and log that before i try much more.
Scott.
I wonder if this datalogs from FC datalogit will work on logworks ?
Scott
RX7
Old 18-12-2006, 10:10 PM
sleeper7 sleeper7 is offline
Default rotary AFRs with water
old thread but trying to bring it back
Currently running two M5 (5gph at 100psi) nozzles and a 150psi shurflo pump. controller starts at 3psi and full at 25psi.
My AFRs are in the low 10s and EGT is max at 675c. Timeing is 20btdc at 1.5 bar.
http://www.putfile.com/sleeper7 short incar video
Two options to get the EGTs up. #1, retard the timing and see if this helps. #2, lean the map out.
opinions?
Old 18-12-2006, 10:56 PM
Option 1 will loose power for sure.
Option 2 is much better but ensure you have a good failsafe system. I believe coolingmist has a failsafe (block jet) you can purchase as an add-on?
Old 23-06-2007, 09:48 PM
markbudgen markbudgen is offline
Hi all,
I get a similar effect which maybe a wide band measurement effect from a cooled exhaust. Here's a picture of the effect in my car.
BR, Mark.
