Old 20-08-2013, 09:06 PM
Default Re: False flow readings from flow sensor.
Originally Posted by yokimazoku View Post
This is probably true. I think i was on the edge of how close i could be bc if i move it over about and inch it picks of the false flow again even when wrapped. I did notice with the hfs 4 that i dont get a set flow on the gauge its always moving. Only time its constant is if i have the car off and in ACC and set the controller to SYS to make it spray. Then it stays at a constant 6 bars. But as soon as i start the car i get an extra 2 or 3 bars bouncing around. I assume thats normal yes? I Even moved the sensor out of the engine bar for testing same results.
Unplug the clip from the sensor body. I if you still get readings, the pulse must come from somewhere else. If reading appears again after re-clipping, the signal ahas to come from the sensor itrself.
Old 21-08-2013, 10:33 PM
skeurton skeurton is offline
Last night, I did a few things....
-Added a second nozzle to be able to inject 100% meth.
-Set the P/I-R trim to full IDC.
-Removed the flowsensor turbine and tried cleaning it again. Didn't completely disassemble it, but ran more compressed air through it.
-Took a piece of wire loom and covered it with several layers of electrical tape. I then placed the whole loom over the flowsensor turbine in hopes that it would shield both the flow sensor and turbine.
Once everything was back together and buttoned up, I started the car and the bars on the gauge were going crazy just sitting at idle while waiting for it to warm up. Took it out for a spin, got on the throttle, and the system was spraying fine. The gauge still continued to show false flow after that. I didn't feel like messing with it anymore, so I left it alone and went to bed.
Started my car this morning to go to work and everything seemed ok. No bars showing as I let it idle. Left my house and everything still looked good. Once I was on the highway, I opened up on the throttle, system sprayed fine, let off the gas, and the gauge started showing false flow again.
8 and a half hours later, I left work. Started the car, everything looked fine again. Got on the highway, got on the gas, system sprayed fine. When I let off, I was expecting the gauge to go crazy again with false flow. TO MY SURPRISE, IT DIDN'T!!! I tried it a good 5 or 6 times on the way home and everything worked perfectly! I was also able to trigger and set the WL and WH failsafes. I even caught a datalog of when the failsafe tripped in high boost. It worked flawlessly.
Now I can finally get to tuning this thing!
Old 21-08-2013, 10:53 PM
Weird...
Did you switch something off between the two periods? ac fans, cold start etc?
Old 21-08-2013, 10:59 PM
Weird...
It is weird, but I did nothing different.
Old 22-08-2013, 07:33 AM
Please keep an eye on it and post.
Old 14-09-2013, 01:46 PM
hotshot25120 hotshot25120 is offline
I have false reading too in my car
here a picture of where my sensor is located :
Old 14-09-2013, 11:00 PM
Can you unclip the sensor at the FAV and tell me if the false flow reading is still there.
Old 15-09-2013, 12:33 AM
dave80 dave80 is offline
hotshot I had the fav assembly in the same location (mkv gti) and no matter what I did the false readings wouldn't go away. I moved it all the way to the left (looking at your pic) next to the coolant overflow tank and that solved my problems.
Old 15-09-2013, 07:43 AM
Do we have a definitive culprit that caused it?
The question still remains:
1) Interference from neighbour noisy cables
2) The sensor turbine is cavitating between the magnetic poles due to vibrations.
Old 15-09-2013, 03:15 PM
Thanks I will try that.
