#31
Leds im getting-
W-injection light constant blue W-level light constant yellow when jet is not spraying W-level light off when jet is spraying Thanks |
#32
How old is this system? It appear the gauge is v10 or v11.
Can you unplug blue harness and tell me if the failsafe light still on?
#33
Not sure what version it is, ive had it a fair while now on another car, ive got a blue circuit board that says HFS3-PWM
Taking out the blue harness appears to make no difference to w-level light being illuminated |
#34
HFS3-V1K ISS1 L2 printed on back of board
#35
When you first post said you just installed the HFS3, I though it will be the lastest v3. Hence I was confused with your description. I should have asked you first before diagnosing the problem.
OK, lets start again. Is this a brand new system out of a box?
#36
It was, I took it of my old car and was in storage for a while, ive bought new harnesses, jets, water lines, filters and fav before the instal on my current car
#37
#38
#39
V1 has a blue circuit board.
I think it would be easier you can make a trip to us (East Sussex) I will be able to test out the controller for you. It is not easy to pin point a problem if the system has been in service for a while and re-installed into another car.
#40
Ok that would work fine for me, when is best for you?
