Old 27-09-2016, 05:53 PM
Default Re: HFS-3 not spraying ::mystery solved::
Yes, the SSG is "all on or all off", not progressive.
Wiring is the same. Post a picture first, might saves you some money
Old 28-09-2016, 01:54 PM
Arthurwiljami Arthurwiljami is offline
Taped one of the nozzles to the hood and tested the SSG. It started spraying around 3500rpm but still didn't see any leds in the bargraph?
And failsafe activated again. Why when the system does not read IDC?
What component gives the bargraph the signal how much water is flowing because I can't get any of the 8 leds to li up, not even when doing a flow test?!?
Old 29-09-2016, 08:08 AM
If there are debris trapped in the flow sensor, it will stop the turbine spinning and will not show flow on the gauge. Try disassembling it and give it a clean. (carefully)
