#11
Re: Ecoboost Mustang
I will only do the drawing for the HFS4 but you can you use it for HFS3.
#12
Great! Thank you Richard. You have been more than helpful. Let me ask this am i going to have to do any board reconfiguration or should it be good to do since the MS3 is also DI?
#13
It will be the same as MS3. No guarantees. We shall see.
#14
Sounds good. Thank you
#15
This one may work:
#16
i'll try it out and report back. I don't have the x2.5 jumper. I belive on my HFS-3v2 that is a solder joint on the back of the board. It should be already set to 2.5 but i will find out when i pull the box out of the speed. Thanks so much for your help.
