Old 18-05-2018, 12:08 PM
rallyfreak202 rallyfreak202 is offline
Default New install issues
I’m glad this forum exists. I did some searching and couldn’t find my exact problem although it could be from a clogged line. Please weigh in on your thoughts.
Purchased new late 2017. Installed in 1995 Audi S6. 5cyl turbo. 630cc DEKA high impedance injectors.
Problem 1: “B” on gauge illuminates and then water level sensor illuminates. No flow shown in this condition. I can hear controller click and unclick when condition goes away. I noticed this when I tweaked the SC.
Problem 2: very little flow. Before fault listed above and SC tweaking, I only saw flow at WOT and even then it’s not full flow. Only brief flow. This was right after install but now I have another problem. I adjusted the THRES, GAIN, and FS-DL with hopes of getting more flow from the system at earlier onset. No luck. I believe we should solve this problem after solving the first.
What I’ve done: green IDC illuminates while running, SYS jumped with PRK to see manual flow post FAV (flows well but engine must be on to see flow), and banged my head out of confusion.
Old 23-05-2018, 05:02 PM
Default Re: New install issues
Did you get a wiring diagram with the kit with the correct engine code?
Old 23-05-2018, 09:23 PM
No, I did not. I used the generic user guide wiring diagram. My engine code is AAN. 1995 Audi S6, 20v 5cyl turbo. I am using VEMS engine management with stock harness.
Old 27-05-2018, 04:43 PM
Have you checked the injector +/- splice are not swapped?
Old 29-05-2018, 09:32 PM
I have not. I do have the blinking green LED on the controller board. I think this signals injector pulse. With this working correctly, does that mean I have it wired correctly?
Old 30-05-2018, 09:45 AM
If the wires are swapped incorrectly, The controller will click as well as the green led. If the connections are correct, only the green led blinks, no clicks on the controller.
Old 30-05-2018, 11:54 AM
Also can you tell me the serial number of the controller.
Old 02-06-2018, 11:16 PM
I verified the green wire is going to ground side of injector and red is going to positive. I did notice that the negative side of injector (green on Aquamist) would show 14v when keyed on with injector unplugged and only the ECU harness connector plugged into controller. My other injectors will show voltage on negative side when ignition cycled and injector plugged in (no voltage on net side when unplugged and ignition cycled). I’m guessing this is normal.
Now what do I test?
103055
